05 Trailblazer high neams not working
I just bought a 2005 Trailblazer LS 4x4 and love it but the high beam headlamps don't work. All the fuses seem to be good and tried replacing the bulbs and nothing. Any ideas??
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> cupofchicken,
It sounds like a fuse issue, but I cannot be positive. Since you stated the fuses are good and the bulbs have been replaced, it may be a wiring issue. I would suggest visiting your local dealer for an inspection. They should be able to pinpoint the problem with more accuracy. Best of luck and keep us up to date!
Louis
GM Customer Service
Louis
GM Customer Service
otis_xing
Silverado & Fullsize Pick-ups
April 13th, 2013 2:31 PM
rsaz
September 15th, 2008 10:41 PM
