TrailBlazer 2002-2009
The TrailBlazer, originally introduced as an upscale Blazer, was produced from 2002 to 2008 with a powerful I6 engine and with a monster V8 offered in the Trailblazer SS
Won't go past 50 mph
Old June 16th, 2015, 9:36 PM
Brazy's Avatar
Default Won't go past 50 mph
Hello my friend gave me a 2002 Chevy trailblazer with 178,041 miles on it and it won't shift past 50 mph can you guys please help me out thanks in advance
Old June 16th, 2015, 9:49 PM
Rednucleus's Avatar
What do you mean it won't "shift'. Also more specifics on motor, tranny would be nice!.Thanks, Red
(I'm old and need lots of info to be of any help lol)
Old June 16th, 2015, 11:45 PM
Brazy's Avatar
Yes it won't shift into 3rd gear
Old June 19th, 2015, 12:21 AM
KChevy75's Avatar
Should be a 4L60e Trans. Does it act like it's in neutral when it should have shifted into 3rd and 4th?
If so, it's a worn 3-4 clutch pack. There's just not enough clutch material left for them to press against the steels.
You'll have to rebuild it or replace it with a used or remanufactured transmission.
I rebuilt mine myself. I've rebuilt a few and this one is very easy to rebuild. There are several step by step 4l60e tear down and rebuild videos on youtube.
To rebuild it yourself, assuming no broken parts, you'll need a master rebuild kit with at least the seal kit, 2-4 band, filter, friction clutches and steels ($180). I recommend new bushings ($30) and the molded piston set ($30). I also highly recommend a reman torque converter ($150 at your local auto parts store). You don't know what's hiding in the old one plus you can't flush all the junk out of them.
You can also do a Google search for "30 Common 4L60E Transmission Problems & Repair" for a lot of good info.
G T Igofast
Silverado & Fullsize Pick-ups
September 3rd, 2013 3:46 PM
ericthegr8
May 29th, 2013 2:38 PM
vmabuck
March 9th, 2012 12:24 PM
davegpete
November 18th, 2006 9:31 PM
techno_farmer
March 13th, 2005 9:41 PM
Quick Reply: Won't go past 50 mph
