Passenger side front window won't work
My 2009 Chevy Traverse front passenger window fails to work. When I push either the driver or passenger button, I hear a clicking noise at the switch. I assumed that if power was getting to the switch the regulator was the issue. I replaced the regulator with a new one but the problem still exists. I don't see any threads on the problems with the Traverse window issues. Does anyone have any ideas on what to look for to identify the problem? Since I replaced the regulator, my window is now stuck in the down position.
It can be either front switch or some wiring in the door jam. Having a good wiring diagram can be helpful, alldatadyi has a day fee.
Same issue
I replace the regulator to find out that the switch may be the problem. I ordered the new switch and replaced it. That did not solve the problem. I tested the voltage on the output of the connecter itself. I got 12 V positive and 12 V negative. I assume one is for the window to go up and one is for the window to go down now when I plug it into the regulator, nothing happens. I took a 12 V battery and hooked it up to the brand, new regulator, and it went up and it went down with the window attaché and secured in the door. I then tested the connecter again and it was still giving me 12 V - and 12 V positive. I then cut the connecters off and crimp the two wires together to the wires that they go to and the power windows still do not work. I have no idea why the power window on the passenger side won’t work. The lock is not on. It doesn’t work on the driver side when I push the button and it won’t work on the passenger side when I push the button even though I had a new button replaced, I am getting 12 V to the wires the window should be going up and down, but they are not. What is going on?
Desp
Silverado & Fullsize Pick-ups
October 3rd, 2016 7:06 AM
Soxman
September 8th, 2014 12:21 AM
