2006 uplander
Since its winter, I'm thinking that gaftop is likely running the heater in his Uplander...when the floor vents are selected, the compressor and cooling fans will run on and off...fans on, 12.something volts...fans off, 14.something volts...
Just like our Uplander....
Running the AC you will notice it especially when driving in town. Our lights will quickly dim and come right back when the fans kick on. Sounds like you have no worries!
2007 chevy uplander cooling fans
2007 chevy uplander ,,, cooling fans will not come on when you turn the ac on .... if the ac is off the fans work ,,, replace almost every sensor and switch ,, any ideas ????
Varying Voltage
The Voltage on my 2008 Uplander has done the same thing since it was new. I think this is normal for this vehicle, I haven't had any problems with mine. As a precaution, I replaced the Battery this winter, we had unusually cold weather.
Alternator Breakdown
My Alternator breaks when it reaches 141K not to mention the idling when in winter time, start the car early to warm us.(Uplander 2006).Hope this helps for the lifespan of alternator.
