Uplander 2005-2009
Platform: U-Body
2006 uplander
Old January 6th, 2013, 7:39 PM
gaftop1's Avatar
Cool 2006 uplander
starts ok shows 14.7v then it will go down to 12.9v varies between the high and low voltages. alternator going bad or is it normal??????
Old January 7th, 2013, 6:12 AM
442dude's Avatar
Sounds pretty normal to me - I would be more concerned if it stayed at the high or the low. Still the factory battery?
Old January 7th, 2013, 9:53 AM
I don't have an Uplander, but my voltage stays constant at a bit over 14 volts all the time.
Old January 7th, 2013, 2:39 PM
442dude's Avatar
Since its winter, I'm thinking that gaftop is likely running the heater in his Uplander...when the floor vents are selected, the compressor and cooling fans will run on and off...fans on, 12.something volts...fans off, 14.something volts...
Just like our Uplander....
Old January 8th, 2013, 4:46 PM
gaftop1's Avatar
Wink
not factory battery and i'm on the gulf coast so, not running heater running the a/c.
thanx for the replies
Old January 9th, 2013, 8:16 AM
442dude's Avatar
Running the AC you will notice it especially when driving in town. Our lights will quickly dim and come right back when the fans kick on. Sounds like you have no worries!
Old April 22nd, 2014, 8:36 PM
bawg7980's Avatar
Question 2007 chevy uplander cooling fans
2007 chevy uplander ,,, cooling fans will not come on when you turn the ac on .... if the ac is off the fans work ,,, replace almost every sensor and switch ,, any ideas ????
Old April 26th, 2014, 2:21 PM
442dude's Avatar
Cooling fans don't come on at all when AC on? In our 2008 they don't come on all the time with the AC on - they cycle on and off while you drive.
Old May 1st, 2014, 12:36 AM
yjf1535's Avatar
Thumbs up Varying Voltage
The Voltage on my 2008 Uplander has done the same thing since it was new. I think this is normal for this vehicle, I haven't had any problems with mine. As a precaution, I replaced the Battery this winter, we had unusually cold weather.
Old September 16th, 2014, 1:47 AM
Patriot's Avatar
Default Alternator Breakdown
My Alternator breaks when it reaches 141K not to mention the idling when in winter time, start the car early to warm us.(Uplander 2006).Hope this helps for the lifespan of alternator.
ZiL
Uplander
February 15th, 2011 8:45 PM
edwin259
Uplander
March 19th, 2008 4:22 PM
RoadWarrior
Uplander
November 10th, 2007 10:25 PM
derekjay
Uplander
June 27th, 2007 12:40 PM
derekjay
April 25th, 2007 1:35 PM
Quick Reply: 2006 uplander
