Uplander 2005-2009
Platform: U-Body
2006 Uplander electrical gremlins..
Old February 25th, 2015, 1:09 AM
  #31
albertauplander05's Avatar
I replaced my voltage regulator just last summer, fixed all the light problems up and the voltage was correct as well. I just replaced my battery again after maybe a year???? My voltage is strange though.. 12.7 volts on the highway, and 14.0 on idle??? Had the battery tested, rated at 660,Delco Proffesional, putting out 707 cca?? Ideas?
Thanks
Mike.
Old October 21st, 2015, 8:54 PM
  #32
EquineGirl798's Avatar
I had problems with the gas gauge to and what I did was replace the reader and the fuel tank,
Old October 21st, 2015, 9:03 PM
  #33
Smile Third Brake light
I went in to have my oil change done today and the technician showed me that my third brake light (center) is not working. I thought there would be a warning if it was not working but I guess not. I'm sure its just burnt out but could there be any electrical problems that I am not aware of?
Old October 22nd, 2015, 7:25 PM
  #34
chevy55's Avatar
it could be a wiring issue to the third brake light or the led board could be done.an easy way to check it would be remove the light assembly out of the rear hatch and detach the connector .get a test light and with the ignition on have someone apply the brake pedal then check for power at the plug.i almost forgot to say check fuses first.i have a 2005 that has had very little electrical issues like 3.the telltale in the instrument cluster will usally tell you if you have a burnt bulb out.i don,t know if it would tell you if the third brake light is out.
Old October 23rd, 2015, 2:34 PM
  #35
Default Tail light
Thanks for the advice I took it in today and had the assembly replaced
Old October 23rd, 2015, 4:04 PM
  #36
chevy55's Avatar
no problem.
Old December 11th, 2015, 5:45 AM
  #37
rick444's Avatar
I think i will try the foil wrap on the connector. Maybe some 5 ohm resistors on the akternator sense lines. Or get a new regulator.
I hear gm tried some novel tricks to improve charge system but things went badly.
Old February 20th, 2021, 12:28 PM
  #38
Terry Coltrain's Avatar
Default Neutral Gear selector light stays on
Hey everyone, I have a 05 Uplander that the Neutral light stays on all the time even when put into other gears. Any idea what may cause this?
nole76
December 15th, 2008 12:06 PM
gdebeneditto
Sonic (Aveo)
October 23rd, 2008 6:13 PM
Thadeus13
October 18th, 2008 2:10 PM
Jfranco
August 12th, 2008 2:22 PM
user77877
January 22nd, 2007 11:20 AM
Quick Reply: 2006 Uplander electrical gremlins..
