2007 Uplander AC Problem
My Uplander's AC doesn't work, I can start the vehicle, the ac clutch comes on, the cooling fans turn on, the ac clutch turns off, and the cooling fans stay on. No cold air comes out of the vents at all, I checked the pressures with the engine running and have about 105 psi on the low side and about 365 on the high side.
Any help would be appreciated.
Hi there,
I believe you have to drive the van in order for it to start blowing cold air. I noticed that in my 09 uplander, it works perfect while driving, but not as cold at idle. hope this helps
Had the same problem. If you are hearing the condenser turn on then the AC is working but soemthign is stopping in. In my case it was 2 things. there was a battery electric wire that was frayed and touching the condenser thus causing a electrical surge. When that was fixed, the condenser would keep working but the cold air was sooo not that cold. so the filters needed to be changed. somehting i neglected. When that was changed, low and behold, my ears feel like they are freezing!!
Hope that helps
Hope that helps
ilanitin
Uplander
December 26th, 2008 7:54 PM
djudkin
August 9th, 2007 12:53 PM
