any advise BEFORE I buy an '07 Uplander?
I wasn't familiar with the Uplander prior to seeing one advertised for sale (2007 Uplander LS ). The limited production run makes for little online information on long-term issues common to this model. Any advise ? Will be used as a 2nd vehicle, and for light towing.
check underneath for frame rust and rotten floorboards. literally every floorboard I have seen in the midwest is destroyed...
plan ahead and budget for transmission issues. there are known issues/tsb's regarding insufficient magnets and solenoids getting contaminated with ferrous material which will eventually leave you stranded or gingerly limping home.
The cooling system is a bit touchy too. monitor gauges, fans, etc for overheating/leaking
