abs sensor cable
abs sensor cable
has anyone replaced the front drivers side ABS sensor cable . The ABS light would come on in -25 weather then this spring it stayed on. So I bought a new sensor pickup cable because it is the cheapest thing to replace. My manuals are crap they show a drawing but it's too small to see and there is nothing about the sensor pickup. It looks pretty straight forward, but so was the power steering hose replacement on my Impala and that was a Bitch, no room and you couldn't turn a wrench if you got it on the bottom fitting.
Thanks
Thanks
its not to bad you can get new harnesses online pretty cheap from aftermarket sources. many people solder the wires i actually suggest crimping connectors and heat shrink tubing. they handle the stress and movement way better.
SILVERAD01
Silverado & Fullsize Pick-ups
March 6th, 2009 7:11 AM
