Uplander 2005-2009
Platform: U-Body
changing spark plugs......
Old June 23rd, 2008, 9:32 AM
06uplander's Avatar
Default changing spark plugs......
i have an 06 uplander 3.5L that i'm trying to change the plugs on, my only question is how do i get to the 3 on the back side of the engine???
Old June 23rd, 2008, 9:48 AM
EvansBlue's Avatar
Default RE: changing spark plugs......
You must unbolt the engine mounts and have someone help you lean the engine forward.
Old October 18th, 2008, 4:45 PM
TittyMonster's Avatar
unbolt the top mounts and push the car backwards, this will roll the motor forward slightly..be sure someone is inside to set the brake before you stick your arm back there..good luck!
Old May 31st, 2010, 5:34 PM
toyman341's Avatar
I can't see how the engine can roll up enough, without destroying the wipper arms
Old May 31st, 2010, 11:28 PM
Professional Mechanic
crateampsrock's Avatar
it will be alright...its set far enough down in there it wont hurt it. its going to pivot over the lower rear mount so it will go forward and down, not up.
Old June 2nd, 2010, 7:33 AM
ice777's Avatar
Useful information.... thanks for the thread. I have read this on the internet before, but not as explicit as stated in this thread.
alka
Astro
January 26th, 2020 2:44 PM
2004CMM
July 21st, 2010 6:39 PM
ddls1
June 25th, 2010 6:09 AM
Lees2500HD
Silverado & Fullsize Pick-ups
June 29th, 2008 6:04 PM
epekarik
July 14th, 2006 12:51 AM
Quick Reply: changing spark plugs......
