how to program uplander keyless entry fob diy?
i know the vehicle had one from the factory because the prior owner had a working one the first time i test drove it... they lost it before i bought the van. i have an unprogrammed remote fob but its been slow-going searching for programming directions... i have an elm327, but havent tried forscan. any tips? thanks
Keyless entry systems have become a staple in the automotive world, and their use is as widespread as power windows. The remote is programmed to work with one specific vehicle, and the vehicle will usually come from the factory with a couple of remotes already programmed to be used with it. If these remotes get lost or stop working, it is possible to order more remotes that will work with your vehicle.
The Chevrolet Uplander keyless entry system relies on remote transmitters for access to your vehicle and control of the lock system. You can add up to four keyless entry remotes to the Uplander's power lock system. Save the expense of visiting a dealer by programming the new remotes at home. Buy a replacement remote from an auto parts retailer or Chevrolet dealer.
