Help problems with 2008 uplander
Hi I'm having a problem with my2008 Chevy uplander the daytime lights and washer fluid won't stop running even when it's not turned on
Both started doing it at the same time? Otherwise its likely a relay with the DRLs and the wiper stalk for the washer pump. The relay for the DRLs should be in the underhood fuse box and you know where the stalk is...
A long shot answer if they both started doing it at the same time would be that the body control module (aka BCM) is failing. Try disconnecting the battery for 10 minutes and reconnecting. sadly its a dealer only repair as they need a Tech 2 to program the new one...unless your local mechanic has one...
I'm hoping its my first guess....
Official GM Rep
Hi Keithpetriejr,
I'm sorry to hear of this problem with your Uplander. I will like to take a further look into your concern. Please send a private message if we can be of any assistance. In the message please include your full name, VIN, current mileage, and the name of your dealership. We look forward to hearing from you!
Kristen A.
Chevrolet Customer Care
Kristen A.
G P Meyers
Uplander
77
April 15th, 2020 2:37 PM
kimble
Uplander
August 4th, 2014 8:17 PM
