Uplander 2005-2009
Platform: U-Body
Old July 22nd, 2015, 1:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
How do I replace a turn signal bulb
Old August 6th, 2010, 11:51 AM
ticu's Avatar
Default How do I replace a turn signal bulb
Uplander 2009.
I believe the front right turnsignal light is burnt (the click noise sound is different). The book says I need a 3157 NAK bulb. I only saw at Canadian Tire 3157 NALL. Sould I buy it or it won't work? Also how do I get to the bulb. The manual ony shows how to remove the headlight block but doesn't say clearly how to get to the turn signal light. Thanks
Old August 7th, 2010, 4:07 PM
srp204's Avatar
Just had the same thing, the blub is the amber coated blub. Now the fun you remove the locking pin, remove the one screw\bolt (12mm I think) then get a screw driver and carefully pry around the rubber molding and you can swing the headlight assembly forward to reach down to the lamp housing. Get a good grip and turn it ccw, the housing pulls out and the blub is a simple pull out and plug in the new one. The housing has 3 tangles that need to be aligned to reinstall the housing, it's not HARD to put it back in is a little annoying. You will then require the driver to get the molding back in place. Next time I do it I'm going to spray the molding with a soapy solution to make it easier. NOTE: this is not something you do at the store parking lot and I'd suggest to run the van through the carwash first to avoid wasps being attracted to the dead bugs in the grille.
Old August 14th, 2010, 12:02 AM
fscoles's Avatar
In order to prevent buggering the rubber gasket around the headlamp, I also loosen the plastic grill near the headlamp by first lifting up (with a screw driver or a plastic trim fork) on the nearby black plastic fastener heads to remove them to move the grill out of the way from the headlamp. This doesn't hurt anything, the fasteners can be reused. A local body repair technician showed me this trick. FWIW the "NA" on the lamp label refers to a traditional Sodium lamp output, which appears as amber in color. The NA automotive lamps simply have the amber colored glass envelope. LL is "long life", and K is for a krypton gas lamp which has good brightness and long life, so LL and K are pretty much the same.
Last edited by fscoles; August 14th, 2010 at 12:12 AM. Reason: wanted to add some information
Old August 14th, 2010, 12:52 PM
Papa Bear's Avatar
Originally Posted by ticu
Uplander 2009.
I would think the dealer would put one in for you under warranty. Watch how the tech does it so you'll know next time.
Old August 27th, 2010, 9:56 PM
fscoles's Avatar
P.B., the chevy dealers must be nicer in your "neck of the woods"..last year I witnessed a local dealer charge a man $75 to replace a blown turn signal bulb in his newer Cadillac (he told me it was still under full GM warranty and he had purchased the car at that dealership new), because they had to remove the front bumper to get to the bulb and they charged him over $10 for the bulb, even though he had purchased a good bulb at Walmart for $1.60; it had to be their bulb so they could warranty the repair. The service manager told him the GM warranty does not cover consumable parts like bulbs. If in fact his bumper must get removed to replace a lamp, then some GM designers should find other jobs.
Old August 27th, 2010, 10:51 PM
Evil~Within's Avatar
There is a "L" shaped lever on the right top of the headlight (passenger side turn signal) (reverse left and right if you are on the driver's side)
1. turn L shaped lever counter clockwise 1/4 turn and then pull it up; releasing the right side of head light.
2. there is a 10mm bolt on the left top of the headlight that needs loosened or taken out.
3. with a plastic trim tool remove the push clips on top grill (pry up gently and remove)
4. swing out head light starting with the right side carefully.( step 3 gives you the clearance, just pull gently on corner).
5. signal is just below the headlight opening. 1/4 turn and it pops out. replace it with a 3157na that is orange in color.
5. reverse process to put it all back together. <!-- google_ad_section_end -->
Old August 28th, 2010, 11:49 AM
Papa Bear's Avatar
Do you mean that light bulbs are not warrantied under the 3 yr "bumper to bumper" warranty ?? I thought that "bumper to bumper" was all-inclusive barring damage or negligence.
Perhaps Jeff Morris, Chevrolet Customer Service , who posts here can shed some light on this... click the contact info on his profile page. https://chevroletforum.com/forum/members/chevrolet-customer-service-37376/
Threads like this is where GM could really score some points. Putting a fire out BEFORE it's out of control.
Old August 28th, 2010, 12:09 PM
when i worked at the dealer the bulbs were only coverd 12mo/12mi not 3yr/36mi headlights were coverd though
Old October 21st, 2010, 9:11 AM
ticu's Avatar
I finally changed the bulb myself a couple weeks ago using the very useful techniques explained in three of the previous replys (Evil~Within,fscoles and srp204 ). Thanks very much , it wasn't hard to do it and I am not a very handy individual, so if I could do it, anyone can do it. Thanks again.
P.S. I couldn't perform this step though: "3. with a plastic trim tool remove the push clips on top grill (pry up gently and remove)" but it worked even without it. Basically I was under the impresion that those "push clips" (or "fastners" as fscoles names them) would just brake if I forced them out. Like I said, the headlamp ensemble came out without removing those pins though.
Old November 18th, 2010, 10:51 AM
dieselscout80's Avatar
For what its worth the front turn signal bulbs can be replaced by reaching up from under the front bumper (no tools needed) on my 2007.
Quick Reply: How do I replace a turn signal bulb
