2005 chevrolet uplander passenger power sliding door does not open....
I am having a problem with my passenger door not opening or closing with the power option. If I push any of the buttons to open it it just pops it open and doesnt slide. It does nothing if I push it while it's open. I can open and close it manually just fine. What would cause this problem? Thanks in advance.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> karabug27,
I recommend taking the vehicle to the dealership for the best diagnosis and repairs of the issue. Let us know how it goes at the dealership.
Breanne
Chevrolet Customer Service
Breanne
I recommend you A) Check the fuse to the motor as it's apparent the motor is not working.
B) check the motor switch
C) check motor if the other two are good. I'd suspect switch needs adjusted.
I seem to have found the problem with my door check the block of 8 pins that are on the side of the door and see if the bracket is loose mine was I pushed the the plastic bolts back in place and we haven't had any trouble with it since.
goyakpacking
Express & G-Series Vans
May 9th, 2015 7:51 PM
LeeHamilton
October 26th, 2014 9:49 PM
chevyLS6
Uplander
May 13th, 2014 4:25 PM
