Noise in reverse
Noise in reverse
Since last fall when I reverse out of driveway or parking space I randomly hear a rubbing noise (brake ???) from rear mostly passenger side rear. seems to be most common in cold weather but occurs in all weather. Cannot see anything rubbing tire or wheel. usually only occurs once for a few seconds and then usually dont hear again for that day. Any ideas. Will it harm anything. Is it a sticky caliper? any thoughts
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> rdc1534,
It may be a caliper issue. I encourage you to have the vehicle inspected by a certified technician for a more accurate diagnosis.
Please keep us posted.
Louis
GM Customer Service
Louis
GM Customer Service
update
The noise is so random and intermitttent that I cannot bring it in yet because it would just be a frustration of be a could not duplicate problem.
Morphsuit
Silverado & Fullsize Pick-ups
October 8th, 2013 6:06 AM
bobehud
August 9th, 2011 5:22 PM
snowdriver
December 12th, 2007 11:43 AM
