Rotor replacement on 2006 Uplander
This may be a dumb question but are you sure you even need one? I have an '08 and I'd be a little surprised that anyone other than the original owner would have rotors with the torx bolt still installed.
At least my rotors didn't have the torx screws
t-30
before you remove it. hit the rotor face near the torx screw. this shock moves the rotor in and takes tension off the screw....which can easily strip if you don't do this.
