Venture 1997-2005
Platform: U-Body
02 Venture heater/AC blend door
Old February 25th, 2011, 4:55 PM
wally3b4's Avatar
Default 02 Venture heater/AC blend door
I am having trouble with very little air flow coming from the vents while running the heater. If I switch the temp control from warm to cool, the air flow increases dramatically. I can also hear a change in the blower motor rpm as if there is a restriction when the temp control is set to warm. I have some dash components disassembled and can see the blend door actuator fully stroke from one position to the other so at least everything up to the blend door is working properly. Can someone tell me how the air flows across the heater core and what I should be looking for next? Any tricks on how to access the blend door without tearing the whole dash apart?
Sixty7camaro
Cobalt
April 13th, 2020 8:57 AM
los7883
April 12th, 2010 9:36 AM
mgnui
March 13th, 2010 12:26 PM
yitz0550
January 14th, 2010 11:23 AM
scesfiremedic
February 13th, 2009 5:20 PM
Quick Reply: 02 Venture heater/AC blend door
