1999 Chevy Venture no oil pressure and bad misfire
Hi I need some experts on here to chime in and give some advice. About 1 month ago I was out and the oil pressure light instantly came on and the van started jerking and misfiring so bad that it would not stay running. Oil level was fine. Oil light had never been on before just instantly came on and instant misifire. Van will not run long enough to check anything. The engine seized on me after I rebuilt the oil pump. I was starting it off and on and then it seized. So I replaced the main and rod bearings thru the bottom while the motor was still in the van. Not as hard as one would think. The crank looked fine and I plastigaged it and it was still within spec. Loaded the oil pump with vaseline, Read alot of success stories on it being ok to help prime the pump. Put it all back together and still the same problem. Oil light on and still bad misfire. Checked rocker arms all were tight but there was a few push rods a little loose, Not enough to hurt anything I would think. Could it be the camshaft bearings? Or bad lifters? Would bad lifters cause no oil pressure at all. Head gaskets were replaced back in the spring and van was fine until instant oil light about 1 month ago. Also took fuel rail up and the front 2 fuel injector holes near drivers side were full of gas to the point of coming out of the hole. What would cause that to happen? Really do not know what else to do in short of pulling the engine and rebuilding it. Please reply as soon as possible. Any advice is great advice to me.
That is old school.
Petroleum jelly is a solid? It will dissipate with heat. There is several things on google about it and everything I read says it is fine because the heat will do away with it fast.
Broken camshaft? Bummer. So the pump wasn't even turning? Thanks for letting us know what you found.
By the way, I know about the vaseline trick. Pretty common, especially if you install the pump but aren't going to run it for a few days and don't want the priming oil to leak out.
