98 Venture passlock issue? stumped...
#21
Fixed!
Well it was not a security issue. I ran an auxiliary ground wire to the body from the case of the pcm. The pcm needed a valid ground. Now it drives. Thanks for the input people.
#24
Check all your sensors, my issue was solved because the 24X Crank Sensor had a wire completely broken on the harness side. When I had it running the car never threw a code (P0336) but that was it all the same. Check 7X and 24X crank sensors and wiring as well as Cam Sensor. It apparently is super hot by the 24X wiring, in the front of the engine, plug is on top of the A/C Compressor.
#25
