Venture 1997-2005
Platform: U-Body
2000 chevy vre. Right Turn Signal flashing fast
Old August 19th, 2009, 6:25 PM
nta3392's Avatar
Default 2000 chevy vre. Right Turn Signal flashing fast
I Have a 2000 chevrolet venture that when i turn on my right signal on the flashing light on the panels ticks and flashes twice as fast, than the normal left signal.
the taillight flashes twice as fast , but the front does not flash at all.
I've switched all bulbs and they all work. The front's turn signal & light bulb does work(as i see it lit when i turn on car) but wont flash when i turn on that right signal.
??? any help ??
Old August 20th, 2009, 6:20 AM
bertherr's Avatar
Default Fast Flash
Try replacing the bulb that is not flashing again. It most likely has two elements in it. One is for flashing the other for constant on. When the current sent to the bulb can not be used to light the bulb it causes the flasher to flash faster. A rapid flasher almost always indicates a bad bulb. Bert
Old February 4th, 2010, 3:17 PM
kristie82601's Avatar
Default similar experience
i had a 2000 venture and when i would step on the brake my signals would blink twice as fast i had to replace one of the back lights the whole thing i had a ahort
Yogi
December 12th, 2021 6:25 PM
kc5uzd
Express & G-Series Vans
January 25th, 2014 8:00 PM
92Nautiquesnob
October 6th, 2009 12:26 PM
NoBrakes
April 15th, 2009 6:14 PM
jogodlew
December 22nd, 2006 8:23 PM
Quick Reply: 2000 chevy vre. Right Turn Signal flashing fast
