Thankz for the help!
Well I think the water pump pulley part is an error.
Makes no diff with the water pump pulley is on or off. It's the power steering pump pulley that was in the way.
I've managed to remove that with the correct puller and installed the new sensor. Now I can't seem to install the darn pulley ! There is not enough room for me to get the tool in to get the darn pulley put back on.
From what I can tell the pulley has to be put back after you remount the pump asembly.
