DRLs Suck!
DRLs Suck!
I always disliked the way the daytime running lights were on these vans. So, I did something about it. A couple little mods, and now the van is visible even in the brightest daylight! Basically, I put Cree LED projector bulbs in the original turn signal locations, then drilled out new locations underneath for LED turn signal/ park lamps. That's kinda the easy part. I had to mod the electronic turn signal flasher to accept the LEDs, then mod the DRL module to turn off the corresponding projector lamp when the signal is on. If anyone is interested, I can put up pics and details for the mods, they are not too difficult, but you should be able to use a soldering iron, and basic hand tools. cheers
canucklehead
Express & G-Series Vans
May 10th, 2013 11:48 PM
camarohauler
Silverado & Fullsize Pick-ups
November 30th, 2010 1:41 PM
