heater hose?
heater hose?
On my 2003 Chevy Venture Warner Brothers Edition a water hose that is between the engine and the firewall broke off. I am pretty sure that it is a heater hose but cant find a replacement for it. Can someone show me a picture of the heater hoses and fittings for this car?
you are going to have to remove the front mounted engine stabilizers to roll the engine forward to gain access to the area. I thought I got mine at O'rielly's but can't remember. I would replace ALL the heater hoses one I rolled the engine forward to gain access, as it's a PIA and might as well spend a couple more bucks and prevent any future failures and needing to go behind the engine again. Not really that hard but make sure and block the tires, and put on emergency brake so the car cant roll with the engine in neutral. It takes some muscle and think I used a ratcheting tie down to help roll the engine forward and back into place.
Good luck
Good luck
Chris Oakley
October 28th, 2012 2:58 PM
kevinf
November 16th, 2008 3:32 PM
