need location of vss (speed sensor wire)
I'm trying to find the location of the speed sensor wire in my 2000 venture minivan so I can hook up an aftermarket navigation system. Any suggestions? Thanks!
go to the cruise module under the hood. If you don't have cruise, the connector is usually tied up under the hood near the air filter box somewhere.
Pin K is a dark green wire, that is your VSS
You can also get the wire at the PCM, Connector 1 pin 55 Dark Green Also
ekoam
October 9th, 2010 1:40 PM
