Questions on a 2002 Venture
Hello! Just purchased the above as we wanted an older van for commuting purposes. My wife has driven it mostly since purchasing this past weekend. She drove it home from the location where we purchased 275 miles away. There are 3 items that we've noticed at this point. They are as follows:
1) Power locks do not lock or unlock. The system chimes 3 times and you can hear the relay click when you press the lock button but nothing locks.
2) Drivers side window goes down but slows while going up and stops. Need to help to pull slightly on the window to get it to close.
3) This may be the biggest issue (expense) as i viewed a few posts....the fuel gauge seems to not register as it should. It is somewhat erratic but seems to register the correct amount of fuel when stopped.
I would appreciate any help or advice.
Thanks!
Thanks!
common2002 Venture problems
my 2002 venture has same problem with fuel gauge and driver's window. I was quoted $1000 to fix fuel gauge. Something about it being a whole part and can't just replace the pump.
rsmith7964
October 27th, 2009 6:14 PM
