Venture 98' Rear Power Windows Issue
Hi Guys,
I have had this issue for a while, but I did use a simple solution always - leave them closed, as summer is approaching I would like to fix this.
So problem is very basic both rear power windows doesn't work consistently. They can work fine one day and they will not work on next. Or they can open just fine, but they will not close. Or one will open, second will not in no particular order.
Basically those things are super unreliable. Do you have any suggestions to fix it?
Thank you!
Thank you!
Another possibility is loose or bad connections at the switch and/or the motor. Check as much of the wiring as possible for worn insulation or weak spots in the wiring.
Is there parameters I can check for with multimeter? How many Volts should be in the wire?
Thanks!
Measured on of two motors and it has about 12.8V coming in when engine is running, but it doesn't work with Window attached to it. When it's detached works just fine.
Tried to grease all moving parts so that there is minimum of resistance when motor moves, but it didn't help.
Thinking about changing motors to manual latches so that there is some reliable, old-fashion windows opening mechanism...
Went to auto wrecker and they told they are not selling latch alone. I guess those windows will have to stay closed until I figure out how to solve this issue...
knarly gto
July 6th, 2013 8:00 AM
spedaleden
September 11th, 2011 2:03 PM
sidewayzpimpin
June 12th, 2007 6:40 PM
