Venture twin Montana whcih AC Delco plugs?
Several forums say use AC Delco plugs to prevent misfiring etc. 2 AC Delco plugs listed. AC 14 regular Rapidfire plug and the AC 41-940 Professional Platinium. The AC 14 plugs are heat range 3 and the AC 41-940 plugs are heat range 4. I guess the 41-940 are hotter.
Engine not burning oil (leaking some). Which ones should I get? Car has 90 K miles and is 12 years old (1999).
Where did you get those plugs and where were they made? There shouldn't be any need to gap them but you can if it makes you sleep better. Just try not to rub on the center electrode. Or, get NGK Platinum plugs.
rainman89
January 2nd, 2014 8:20 PM
texasflyfisher
Silverado & Fullsize Pick-ups
September 25th, 2010 2:02 PM
compguy
February 6th, 2010 11:13 PM
jdmae86
January 8th, 2009 10:18 PM
dbrog28301
Colorado
May 21st, 2007 9:48 PM
