Water leakage in weird place!
My 2002 Venture has a constantly wet carpet on the drivers side floor. It seems to be worst right under the emergency brake pedal. Its so wet it will seep out and make a damp spot on the ground.
I'm pretty sure its not coolant or wiper fluid, which leaves either a rain leak or AC condensate (but condensate usually leaks out on the passenger side).
Anyone had this problem? What is it, and how do you solve it?
Thanks in advance
schuh
Thanks in advance
schuh
Maybe the rubber around the door is ripped and letting the rain in. Or on top of the windshield the metal is rusting out and the rain is running down to the floor. When I had my windshield replaced the glass place said on top by the drivers side it was rusted out. They filled it with glass glue stuff and said it might leak and it might not. They did say it will leak someday because it will keep rusting until I take the windshield out and fix it. The rain water will travel to some weird spots. lol
Good luck.
Dan
Good luck.
Dan
hvtdrt
Silverado & Fullsize Pick-ups
November 1st, 2010 10:40 PM
Fightn17
10
April 8th, 2010 12:45 PM
