1996 Silverado ac compressor question
#12
I was just thinking that in summer when it gets hot, he is going to want to put the AC back and this would make it easier. And it really doesn't hurt anything.
#13
@oldchevy I figured he didn't care about having A/C since summer is quickly approaching, and he also seems to have intrest in not using it. We don't know if it is a work truck, or a daily driver, for the money it may not be worth it to him. the thing I like about his current set up is that if anyone wanted to put A/C back on the truck, it wouldn't be that hard, especialy if he doesn't take out the rest of the system.
#15
So, I have a 1996 Silverado 1500 with a 5.7 vortec. My ac compressor was going bad so I bought a bypass pulley and replaced the compressor with it.
This pulley sounds like ****. Sounds like the bearing is going out.
looking at the diagram under the hood, it shows routings for serp belt for both with ac and without ac. My question is... can I just go to autozone or another store and just buy a belt sized for without ac? I believe they made these exact trucks without ac so shouldn't it be the correct size so I can just bypass the whole compressor/bypass pulley situation all together?
Those diagrams are exaggerated in the details so the correct routing can be clearly seen, but without the idler pulley on a non-AC set up, the shorter belt would either be too long for the tensioner to take up slack; or if it did still tension the belt, it would be rubbing on the water pump pulley on its way to the alternator. Since the belt routes over top of the water pump pulley, the belt would rub against itself.
The AC bypass pulley is accomplishing the same thing as the idler pulley and shorter belt would. Take the bypass pulley back to auto zone for an exchange - at a month old, there should be some kind of warranty on it.
Also, don’t shop at auto zone. You can’t trust any parts house that asks if your truck is 2 or 4 wheel drive when you’re trying to buy windshield wipers.
#16
curiousvi
August 19th, 2015 2:58 PM
