1997 Silverado
1997 Silverado
Hello All.
I have been at this for a while. (I gave up for a while but am ready to tackle this again)
I have a 97 Silverado that will not start.
At first I would run rough and was hard starting, harder when it was wet outside.
I have done so many things that I really cant remember what I have done but would like to start trouble shooting it again, even if it is from the beginning.
So....is there a guide that I can use, perhaps in these forums.
I would love to get this Truck going and back on the road again.
So what I am looking for is a step by step guide to check and test different components.
Let me know!!!
Thank you
Let me know!!!
Thank you
Hard to start or rough when wet outside? Loss of power under load when rainy and humid as well? Cap, Rotor, wires, plugs but most likely the COIL. IF you haven't done any or all of these in the last 60,000 miles you should. probably fix it. It can run fine in the summer, but humidity is extra resistance on wires and component and if the coil is going it just doesn't have the amperage to power through older wires etc. Changing some of it will improve, but if it's been 60,000 or more since you have done it I would do all of it. I get 100,000 usually out all of these with mine, but most people never change them on their 90 C/K's. and it's usually the problem. Might not be the issue, but at least all of this is easy and cheap if you haven't done it in 60,000 or 5 years. Look for mice or voles nests and nibbling on wires. After that then it's time to invest in a code reader and see if it can give you any ideas of where to start.
Actually it stopped starting...Coil has not been changed although I do see spark. It is Cheap to replace so that is a good part to try changing, I did change wires, disc cap plugs rotor a while back. It has sat outside now for years. I really would like to get it started. So at this point I am looking for a step by step guide to trouble shoot a no start condition. I probably need to start the troubleshooting over :-). I don't think I had any codes. Since it has not run in such a long time there won't be any until I start it. Or while just cranking will it throw codes. I will have to check.
Yes the plugs were replaced. I can't remember when but when I changed the Cap cables and rotor. Other than replacing the coil is there a way I can check the coil?
