1998 Chevy Silverado K2500 codes P0172 and P0175
The Truck has an exhaust leak but runs fine other than when gassing it the truck is kind of sluggish and hesitates. The codes popped up about a month or two ago and I replaced O2 sensors (They looked damaged) and cleared codes and nothing the light came back. I am currently replacing spark plugs and wires to see if that helps but it doesn’t really idle ruff or misfire so I’m not sure if it’s an ignition problem, fuel problem or exhaust problem
- Mass Airflow Sensor (MAF) (you can clean it and see if that works)
- Defective Manifold Absolute Pressure Sensor (MAP)
- Defective Oxygen Sensor
- Defective Fuel Pressure Regulator
- Defective Coolant and/or Air Temperature Sensor
- Thermostat is stuck open
- Ignition Misfires
- Defective Throttle Position Sensor
- Defective or restricted fuel return line
- Defective Fuel Injectors
Would any throw a code.
Here is a list of issues that might be causing your problem:
- Ignition Misfires
would any of these throw a code if it was bad and I had to replace fuel pump cause it went out now it still runs rich and is sputtering as if it has no gas. I may have air in the lines from having an empty tank and and empty lines since I also put in new filter.
A dirty or bad MAF sensor may not throw a code, but my guesstimate is that that is not your issue. It's never a good idea to run low on fuel with an in-tank electric fuel pump, as the gasoline cools the fuel pump. No, a bad fuel pump wont throw a code on older pre-2005 Chevrolet's at all. I don't even know if they will on newer GM vehicles. Is it making the buzzing noise when you first turn the start/ ignition switch on? Might want to check the fuel pressure at the fuel pressure regulator.
Some of these issues would throw a code, yes. 02 sensors would throw a code(s). As for changing a fuel filter, I've done so with no issues on my 98 K-1500 no problems.
David5292
April 23rd, 2012 6:13 PM
