K2500 tire size
Hi, wondering if anyone knows the largest tire you can put on 1994 Silverado k2500 reg cab.
I have 245/75/16's (6 lugs) but would like a bit more rubber for towing. Considering the Goodyear Wrangler DuraTrac or similar but wondering how big I can go without a lift. Anyone got numbers? Thanks, Ian |
265 75 16 have worked without rubbing on all the k2500's I've had. FYI bigger tires are going to hurt towing more than help.
Thanks burnhedge!
I tow < 10miles and deal with steep boat ramps so figured more rubber= more grip. No real idea myself - am I just plain wrong there? Also ,will 265's work on my standard rims or would I need new (wider) ones? - Again, total novice here! Thanks again, Ian |
Generally speaking wider tire will give you better grip. I have 265 70 17 on my 97 (stock 2010 rims)
Originally Posted by Ian White
(Post 327796)
Thanks burnhedge!
