-   1988 - 1998 (GMT400) (https://chevroletforum.com/forum/1988-1998-gmt400-106/)
-   -   No crank (https://chevroletforum.com/forum/1988-1998-gmt400-106/no-crank-116826/)
Jboc1974 Jun 14, 2024 8:22 PM
No crank
Need help with finding the starter relay on my 1995 C1500 5.7 L. It's not in the fuse box under the hood and there are no relays or fuses under the dash. Any help would be great. I've been looking on Google and everyone says it's in the fuse box.
mountainmanjoe Jun 15, 2024 12:52 AM
Fuse #6. I don't see a relay
Not cranking?
Taken from charm.li :
https://cimg7.ibsrv.net/gimg/chevrol...3dbf2fff83.png
Jboc1974 Jun 15, 2024 7:31 AM
Thanks for that, but I've checked all the fuses and they are good. It's just clicking but the battery and starter have been tested. Could it maybe be the ignition starter switch?
Rednucleus Jun 15, 2024 8:52 AM
Redneck trick - get a helper to hold the key in start position while you lighly tap starter with a hammer - if it starts time for a new starter, even if it tested "good". Any idea how old your starter is?
Jboc1974 Jun 15, 2024 9:38 AM
It's a brand new starter, had it tested before I left the store as this is the second new starter I've been through. I've knocked the starter, but still just a click, but thanks the info.
Rednucleus Jun 15, 2024 9:45 AM
How old is the battery; has it been properly load tested. Consider cleaning both ends positive & neg battery cables.
Jboc1974 Jun 15, 2024 1:48 PM
The battery is a brand new one also, and again has been tested. I wire wheeled all the connections at the battery, starter and grounds (both engine and chassis).
mountainmanjoe Jun 15, 2024 3:02 PM
Originally Posted by Jboc1974 (Post 504576)
It's just clicking
troubleshooting steps taken from charm.li
https://cimg5.ibsrv.net/gimg/chevrol...c9cfef31fa.png
https://cimg8.ibsrv.net/gimg/chevrol...5629c1d2f7.png
Jboc1974 Jun 15, 2024 6:01 PM
I get 2 to 4 volts at starter "B" terminal. All cables are in "almost new" condition. I have cleaned all terminals and connections. Any ideas? Thanks
mountainmanjoe Jun 15, 2024 6:31 PM
try running a booster cable from battery positive to the starter positive terminal and see if it makes a difference.
