Runs great, but timing will not set
I am getting p1345 code for crank/cam correlation.i did not have this code prior to replacing the distributor...now the timing is -20 can retard with old and new distributor. Took the truck to 2 different mechanics to have timing set and they can’t get it lower than -20. Any ideas on what else could cause this issue? The truck starts and runs great! |
Is it maxed out as far as won't go any further? Pull the distributor, and rotate it one gear. That will give you a little more base movement
I have tried that, multiple teeth in both directions ... I’m wondering if the code means something other than timing |
-20 cam retard, what damage will it cause? |
I read some where that when the distributor is removed it has to be re-calibrated usually at dealer don't remember what year that pertains to.
