silverado engine misfire going up a hill
I have a 1993 Chevy Silverado 6 cyl. 4.3 engine, 2 wd, extended cab. I have a problem with the engine missing or acting like a back fire when I give the gas for pickup or going up a hill. If I down shift it is a little better, but when I cruise there is no problem. The mechanic checked fuel pump. changed fuel filter, and checked plugs. He searched for the problem and thought it might be a flat cam. I don't understand this, but I think he might be guessing. the engine now has 175m miles on it. If I am idling it will run smooth and then miss a beat. Any ideas?
Same here. Wife noticed 2003 Sub K1500 hesitating and reported to me 3 days ago. She had just purchased a full tank of mid grade. I first checked the fuel filler cap. It is snug. I got a can of Sea Foam, in case trash or water entered the system. I've replaced spark plugs OEM, then plug wires. I have the fuel filter to install this afternoon.
I observed hesitation first under stress at 3500 RPM, but then even at 1800. Initially observed after reaching operating temp - now, 4 days later it's at cranking and slow driving Dealers tech listened and replied its the fuel pump "going" Doesn't the fuel pump just fail like a light switch? |
Originally Posted by cfrazier34
(Post 216499)
Originally Posted by funbunch
(Post 219557)
When your engine is under load (going up the hill) it will have a more pronounced misfire then when at cruise. What about plug wires and like Bjmac said, your cap?
Thank you Bjmac!
VIN "Z" 5.3 L V8f O'REilly quoted $275 for replacement fuel pump. Your comment is consistent with new info I received privately. Hey, already replaced OEM plugs, wires, filter - it'll have close to a full tune up! |
Towed to dealer
The tranny 4L60E lurches forward in Park, Rev, Neutral,D, 3,2,1 now (four days)
Was able to rock the vehicle 8 feet backward after chucking shifter in neutral. It stubbornly failed to move forward/backward. :mad: Keep ya'll posted |
Cannot remember if this is OBD1 or 2? Is there a check engine light?
No check engine light comes on at all .
What I would recommend, parking brake set, and wheels chocked, with insulated pliers, pull plig wires one by one. If the engine misses, go to the next till you pull a wire, and the engine dosen't change. That will isolate at least to that cylinder. Pull the spark plug, it could be a plug wire.
| All times are GMT -5. The time now is 4:25 AM. |
