Truck fails to start intermittently 2003 1500 Z71
Looking for some help guys before I start replacing unnecessary parts and wasting time and money. So the truck on occasion twice in the last month has failed to start, all the lights and instrument in dash turns on like normal but the truck doesn't crank or make any type of starting attempt. I've had the battery tested by 3 different places and they'e all said the battery is good and had one auto parts test the battery,alternator and starter while the truck was running and they said the parts check out good according to their hand held diagnostic equipment... When the truck failed to start on the occasions I was able to start it by jumping it. Someone has said it was the starter after hearing that comment just for some additional input. Thanks for your time. It' greatly appreciated!!
A redneck starter test is when the condition recurs, have a helper hold the key in start and you tap the starter with a hammer. If it turns over, time for a new starter. These starters will often test good but have intermittent dead spots that leave you stranded. In college I drove my 68 El Camino an entire semester with the hammer method!
Is that the actual size of the bolt in the picture or is it smaller? Looks like it is from the jack. Look at your jack carefully for any missing bolts.
