Anyone had this issue with heater/coolant?
I have a 4.8L 2001 Silverado that has been needing a coolant top off every few weeks for years. The oil is never milky in any way, so the head gasket seems a very remote possibilities. I cannot find any obvious exterior leaks, but I did replaced my water pump as the truck is well over 200K and there was some slight yellow staining under the water pump's weep hole, however, this changed nothing. Thing is, every time I get in and start up the truck, the heater core gurgles a bit, so I'm thinking the leak might be in that area. Has anyone had this issue? Thanks in advance for any assistance so I don't just part swap over and over.
Thanks so much in advance!!! |
My coolant issues
In my 2004 Sierra coolant was leaking out the weephole in the pump, but only if it was in the perfect position. There would mostly be no sign of a leak, then one day there's a puddle. Another issue I had lately, with a new reservoir cap was it was leaking. T test I fed the overflow pipe int a soda bottle. After a week of driving, there was 1/4" of coolant in the bottle. no cap on the radiator seems weird.
In my 2004 Express I was using about 1/2 gallon coolant per week for a few years. No one could find the issue till one Mechanic took a risk and pumped the cooling system pressure tester way past the recommended pressure. Suddenly the pressure would drop and indicate a leak. Water, oil were all fine. When he took off the head and cover, it was covered in a thick black gunge. Blown gasket. [If i recall correctly, maybe16# pressure was the recommended pressure, and it stayed constant for hours indicating no problem. At 20# the pressure would slowly fall back to 18# before leveling out] |
"To test I fed the overflow pipe int a soda bottle. After a week of driving, there was 1/4" of coolant in the bottle. no cap on the radiator seems weird." This is interesting, I'll give this a try. And I agree, a flush topped, sealed radiator is a new thing for me too.
"When he took off the head and cover, it was covered in a thick black gunge. Blown gasket. [If i recall correctly, maybe16# pressure was the recommended pressure, and it stayed constant for hours indicating no problem. At 20# the pressure would slowly fall back to 18# before leveling out]" I'll see if the mechanic I know well has this testing ability. I hope it isn't a head gasket. I have heard head gaskets on certain GM products are common and some very much uncommon. Have you heard such stereotypes? Thanks for your thoughts and experience! |
Had a similar issue on my '22 Silverado last year. The fix was pretty straightforward - my thermostat was stuck closed and needed to be replaced, but a tech I know said it's also possible the coolant level sensor was faulty.
Originally Posted by clanofwolves
(Post 517491)
Interesting, if the thermostat was stuck closed, did your truck run hot at all?
And... the coolant level sensor? I know nothing about that and I feel the '01 doesn't have one at all. And, even if it did, I do have lowering coolant as it's going somewhere. Thanks for your thoughts! |
(Post 517544)
And... the coolant level sensor? I know nothing about that and I feel the '01 doesn't have one at all. And, even if it did, I do have lowering coolant as it's going somewhere. Thanks for your thoughts! Your not getting the radiator full, so it's overheating. It won't fill the radiator full with the reservoir. It leave a space. |
Originally Posted by Syncman
(Post 517492)
Thanks again! |
(Post 517575)
I put a bottle on the overflow hose and it has about 1/4" of coolant after driving it around a bit. What was the issue with that? The cap on the coolant reservoir?
Thanks again! |
Hello; I have had two slow leaks with my 2004 Silverado with the 4.8. Took a while to find the first. I had to remove the plastic belly pan so I could see. Was the O-ring gasket where the water pump mounts to the engine block.
Just found the second leak a few weeks ago. again removed the plastic belly pan. turns out to be a Y shaped hose which runs to the overflow tank. it is seeping at the Y connector. |
| All times are GMT -5. The time now is 10:52 PM. |
