Notices
gas tank neck
Old February 22nd, 2018, 2:45 PM
winksr's Avatar
Default gas tank neck
i just got a 07 classic and went to fill it up with gas and it kept kicking off the pump no matter how much you squeezed the trigger. has any body ran into this same problem? thanks in advance
Old February 23rd, 2018, 1:23 AM
oilcanhenry's Avatar
I have owned vehicles that need JUST the right place to fill at. Thankfully I dont have those vehicles anymore. I assume you tried to fill it slowly?
Old February 23rd, 2018, 7:33 AM
CAMERON SPEAR's Avatar
That is a very common problem. When your pumping fuel the air in the tank has to go somewhere. There is a vacuum/ breathing issue. It's not fixable your just going to have to find the sweet spot. I found that if you don't put the nozzle all the way in the filler neck it works better, you have to stand there and hold it but it goes faster.
Old February 23rd, 2018, 8:16 AM
is the engine light on? if yes, check for codes and post them here.
the air does have to go somewhere....as you fill...it vents out the tank to the evap canister...then out a vent valve to a fresh air filter...any blockages will inhibit filling. if there a problem with the evap system, a trouble code will give you a starting point for diagnostics.
Old February 23rd, 2018, 8:42 AM
Glad your on a chevy Forum with a dodge pic lol.
Old February 24th, 2018, 9:18 AM
I'm a rebel.
best $1000 i ever spent.
