ironworker87 |
February 19th, 2017 6:26 PM |
Oxygen sensor problems
2002 Silverado 1500 LS 4.8L 200k+ miles
Check engine light came on and codes are showing low circuit input on all four oxygen sensors. The "suggested" maintenece from autozone was to change the fuses. I pulled both fuses and niether are blown. So i crawled under my truck and checked all four sensors. They were all tight and wiring looked good. There was no damage or chaffing to wires that i could see and all connections were plugged in and secured. Could the problem still be the fuses, even though they are not blown? Or should i just go ahead and change all four of the oxygen sensors, or at least take them off and try cleaning them?
I would appreciate the help, thanks.
