Should I remove the oil above the last hole on an oil change?
I have a 2005 Chevrolet Silverado with a 5.3 engine. I checked the manual and it said to fill with 6 qts of oil on a oil change eith filter. Oil was drained while I rotated the tires and greased the front end. Wix filter same size as I removed, short. Refilled with 6qts. Drove it around and checked it and it is a little above the last hole on the dip stick. Is it nessary to remove some of the oil till it is on the last hole? Thanks, Gpaw44
