Notices
fuel line replacement
Old September 12th, 2018, 6:11 PM
dusted's Avatar
Default fuel line replacement
can the fuel lines be replaced on my 2002 2500hd 6.0 gas without dropping the tank?
Old September 12th, 2018, 7:11 PM
oilcanhenry's Avatar
Unfortunately no.. I wish I had better news. If someone wants to become wealthy, they can invent a plug-in fuel pump.
Ah for the days when the fuel pump was mechanical, mounted on the engine and cost about $12 dollars at the local part store.
Old September 12th, 2018, 7:15 PM
geo1's Avatar
It's all plastic up top,connections in the front,Napa sells a kit to hook on that plastic,or get high pressure fuel line, double clamp both ends,they also have a stubby line with fitting for fuel filter,do that,put rubber between
