what is the correct torque?
what is the correct torque to tighten the wheel nuts on a 2003 silverado ss?
140ft/lbs
That much? The nuts become stuck very quickly when I after changing wheels. Can't loosen with the same air-impact-tool I use to gently tighten nuts, need long tool and a 3 foot pipe to losen the nuts again.
My Caddy only need 100 ft/lbs. But I'll take your word for it, its a heavy truck with lots of "push"! |
maybe they were over torqued.
your caddy uses 12mm studs the truck uses 14mm studs. do not put any anti seize compound or lubricant on the studs |
