Wheel hubs 99 Silverado 4x4
Hi, I am in a pickel I need to change both of my front wheel hubs and the bolts on the hubs are rusted very badly. I was thinking I could grind the hub In three spots and punch the bolts out will this works? As for the dust shields are rotted off. So getting a grinder in there is no problem.
LOL no you can't punch bolts out.
Try an impact wrench, soaking with lube, heat... (No need to double post by the way) |
Yes it worked fine by grinding the hub where the bolts are. I mean where they screw into the hub grinded there. As the bolt heads there so rotted they where almost like rivets lol
