Cabin air filter in a 2013
Across numerous forums online I determined my 2013 Silverado 1500crew cab Texas edition isn't equipped with a cabin air filter but the dealer insists it is and tells me the filter is $40 to order. Some local auto parts stores say it doesn't exist and some say yes I can order one for you. I removed the kick panel and didn't see anywhere it could be and I've also dropped the glove box and saw no possible location for it. My guess is it doesn't exist but the dealer and some auto parts stores say it does. Does anyone know for sure wether it does or doesn't not have a cabin air filter?
it should be behind the glove box. I have seen some dealer kits come with the filter and door. look for a imprint in the hvac box....it may have to be cut out and then the filter and door installed.
My 2009 had the cutout imprint, I ordered a kit from Amazon that came with the filter and cover, I had to remove the panel under the dash to access, not a hard job to do. My evap coil was covered in dirt and to vacuum it out before putting the filter
