Dual zone A/C not blowing cold air
Good afternoon,
I tried to search google, and search in the forum search but came up with nothing. Here is my problem, my truck is a 2008 Silverado Crew Cab 5.3 with the dual zone a/c, today I started the truck (hadn't been started in 12 hours) and the automatic a/c comes on to cool the truck. about 5 seconds later I notice the a/c is not blowing but is on. The temp is set a 70 on both sides. I try to manually turn up the fan speed but nothing happens, the controller indicates the fan speed is going faster but I cant hear of feel it. I checked the fuses under the hood and everything related to a/c is good. I check the compressor on the passenger side and its cold with condensation. If I change the temp from 60-90 nothing changes in the cab. Any ideas? Thanks |
so the problem is...
-can't control the blower motor fan speed -no temp change when the temp is adjusted cold or hot |
Yes, the a/c appears to by work, just can’t control (hot/cold or hi/low) it. I believe it’s something at the dash |
the hvac module controls all those functions. It has full diagnostic capabilities. have the hvac module checked for fault codes. this will require a full function scan tool that can access body codes. code reader will not cut it.
