Emissions I/M inc
Emissions I/M inc
2010 Chevy Silverado received error codes for knock sensor, evap sensor and large leak. I replaced evap sensor and the check engine light went off, clearing both the large leak and evap codes. I then replaced the knock sensor and that cleared. I still cannot get a sticker because the I/M shows INC not ready for evap system monitor and oxygen sensor monitor. Any advice? Thank you.
Leo
Leo
evap monitors won't run if the fuel level is not between 25-85% full. Will not run if the temp is to cold; temp dependant.
oxygen sensors run pretty quick...google inspection maitenance monitor conditions and maybe you can find what you need to do to meet the drive cycle conditions.
Thank you
I will look into the other issue using your advice.
Greatly appreciated
Leo
