Need headlight help
Need headlight help
I have a 09 Silverado 2500hd. The driver side low beam is not working. I checked the bulb, not burned out but replaced anyway. Checked fuse, not burnt. Any help would be greatly appreciated. Thanks
There wouldn't be a separate fuse for one headlight. Remove the plug from the bulb and use a test light to see if you have power going to the bulb. Also check to make sure th ground wire in the plug going to the bad headlight is working.
