Need headlight help
I have a 09 Silverado 2500hd. The driver side low beam is not working. I checked the bulb, not burned out but replaced anyway. Checked fuse, not burnt. Any help would be greatly appreciated. Thanks
Is there a separate fuse for a daytime running light feature? If so, check that as well.
There wouldn't be a separate fuse for one headlight. Remove the plug from the bulb and use a test light to see if you have power going to the bulb. Also check to make sure th ground wire in the plug going to the bad headlight is working.
check the connecter pins inside the plug ive had that problem before one was bent and wasnt making contact
