2 in lift front. 2 inch wheel spacers
Wife has 2018 crew (2wd)... she wants me to lift the front 2 inches to level and 2 inch wheel spacers to spread the look a little.... I need some pictures if anyone has done this. ALSO where you got the parts. I need to seethisand show into her before I do it....
search on google for pics, you will get more pictures to look at. i leveled my 18 z71. works great easy kit to install. most all brands are the same basically. just adding a puck to the top of your strut. if you do it yourself one tip i learned is swap the struts after installing the spacer. (install the strut from the drivers side onto the passenger side) makes for a easier install. don't forget to get it realigned.
