2014 Silverado 2500HD Wont start - Chevrolet Forum - Chevy Enthusiasts Forums
Lawrence “Kanui” Moiha's Avatar
January 31st, 2018, 6:16 PM   #1
The wife used my truck for work. After work the truck wouldnt start so had it towed home, figured it was the starter. Today changed the starter & the mega fuse 175, but now not only the truck wont start, it also says reduced engine power/ service stabilatrack. Anyone know of a solution or cause? Any help is much appreciated.
nalghamd's Avatar
February 13th, 2018, 3:19 AM   #2
HI,
did you figure out it could be throttle body i have changed mind as used part for testing it run for while than message comeback you need ODBII scanner
February 13th, 2018, 12:10 PM   #3
Problem solved
After taking my truck to the dealership & a diagnostic ran. The problem turned out to be a faulty ECU. Luckily my truck is still under warranty and didnt have to spend any cash.
nalghamd's Avatar
February 13th, 2018, 12:26 PM   #4
Posted By: Lawrence “Kanui” Moiha
Hi,
thanks can you tell me how much it may cost also part no if possible because i m confused between ECM and PCM
also there's any chance how tell if the ECM is died
mind now i have replaced the the throttle body still some times crank some time no crank i had wait for 15 minutes then keep crank but not fired
Sponsors
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
